Sporting Clays Addict
All the kits I see for the '02 specifically state "for trucks built after 05/24/02". What about those '02 models built before then? Is there a kit or are we just screwed as far as adding OEM-type fog lights?
What is the difference in the two '02 models? Mine has the new body style, but was manufactured in late '01. I thought that was the only difference.
Did yours have the wiring harness already in place? I've read of some people who went to put the kit on and found the harness already there. They just had to plug in and then replace the factory switch with the one that pulls out for the fog lights.
SRT-4
if you have a SLT you should have the wiring harness already there
I ordered the kit plus the factory switch and factory wiring harness and found my ST does NOT have the factory wiring for foglights so had to install the kit the standard way, which was still pretty simple
I dont know what the difference is between the different build dates though
I did the same thing and was done the install in 45 minutes, but I have an SLT so everything was plug in.
