1 - 2 of 2 Posts
I have a fluid leak somewhere. I can tell this because I get the little drops of something on the back of my truck. I have washed the truck and a few days latter I see the spots again. I have checked the fluid levels for the brakes, engine oil, trans oil, steering oil, radiator fluid, washer fluid, and axle lube. Everything is showing ok. I see no loss of fluid on the truck. I have looked under the truck and see the spots around the transmission and back. I can not see where the leak is starting at. There is no large area of leakage. Anyone got an idea of what I can check?
Thanxs
All Around Great Guy
On the back of your truck? I would check and make sure that your pinion seals are not leaking, just bring it to the stealer they'll fix it for free
1 - 2 of 2 Posts
