As many of you know, I swear by the Filter-Mag, model# RA365 for my truck-the industrial version. Well, I saved the filter from the other day when I changed the oil. I cut it open and took pics. Here are the facts: I put this on when my truck was unloaded from the car carrier transport truck with 3 miles on the truck. First oil change was at 500 miles, kept the original filter on as I had NO choice-no filter was available for the new 22mm oil threads on truck yet. Second o/c was at 1000 miles-filter was changed-I got some from dealer & still continue to use dealer Mopar filters to this day. I cut open the 1000mile oil change filter & there was 10x more stuff than these pics show. Third o/c was at 1500 miles. I did another o/c at 3000miles. Regular oil was used for the first 3 o/c. At the 3000 mile change I used full synthetic & continue to do so. I do them now anywhere from as little as 3000 miles to as much as 6-7000 miles. These pics are from the filter I put on at 15,500 miles before winter-Mobil 1 0w20 oil. Truck now has 18,950 miles, so there is only 3250 miles on this filter. I CAREFULLY cut it open & kept wiping the metal shavings from hacksaw away, so as not to cross contaminate. There was NO towing or really hard use on this oil. The proof is in the pics. Enjoy
This first pic is of the side where the Filter-Mag was NOT placed. It's from directly opposite side. You can clearly see the bare metal of the inside of the filter housing/case.
A close up of same.
This is where the Filter-Mag was (on the outside of course). You can CLEARLY see the outline of each individual magnet. While this- initially- looks like there is hardly anything there, it is VERY decieving.
Even though I wiped my finger through the debris, you can still see some there if you look closely.
It never stops working, is removable & will last as long as your vehicle does---or longer. To me, IMO, it is a no-brainer !!! :IDEA:
A close up of same.
