fender
570 views 6 replies 5 participants last post by  GotRam01
#1 ·
I need to know if there is welding involved in replacing a front passenger side fender? i have a brand new one minus the wheel liner and i just was lookin for instructions. Is the wheel lining spot welded to the fender? IS there any welding involved with replacing a fender at all??? :help: :help:
#2 ·
From looking at mine because I need to replace my front driverside fender, I don't believe there is any welding at all. That is just from looking at it, it appears to just be a bolt up. I seem to remember a star pattern for the bolts on the fender lining, but I'm not quite sure offhand, someone has to know.
[Redacted]
#3 ·
not positive, but never saw a fender that needed to be welded to be replaced
#4 ·
No welding required,, But I would suggest having a bodyshop paint the inner side of the fender before you put it on. This makes it easier to paint the outside when the install is done. Good Luck!!
#5 ·
Actually if all you got is the fender you do need to weld it to the inner. It is a pain in the ass and the Mitchell crash books show like 4.5-5.0 hours a side to replace them. You have to take the inner out with the old fender and drill all the spotwelds out then weld it to the new fender.
#6 ·
I stand corrected, they are spot welded
#7 ·
thats what i thought..... great looks like my weekend repairs just got some more welding on the list.... this weekend will be long
