Hey Guys I just want to see if there is any interest I have the Stainless Steel Brakes Rear Disc Brake Conversion Kit & Front Brake Upgrade for the 94-01 Ram with Rear Wheel Drum Brakes. It is Currently Installed on my 96 Ram. Use Wise I bet there is less then 20 Miles on them , Not Even Broken in Yet. My Truck was Trailored to Shows and this Kit was installed less then 2 Months before it was put into Storage in 2003 and Not Driven Since. The Rear Calipers are Bare Cast Iron as well as the Front ... and I would Powder Coat them to What Ever color you would like them in. I would also Give a Core Credit for your Front Calipers in Return
Rear Brake Conversion Kit
Poduct Part Number A158
Product Features
Rear drum to disc brake conversion kit. Includes single-piston cast iron caliper with built-in parking brake.
All hardware included.
Caliper includes built-in parking brake.
Rotors available with optional Turbo slotting and Xtra Life plating.
1994-2001 Dodge Ram 1500 (2WD)
1994-2001 Dodge Ram 1500 (4WD)
Caliper Specs
Name Number of Pistons 1 Piston Size 45mm Constructed From Cast Iron Standard Finish Optional Finishes Powder Coated
Rotor Specs
Diameter 11.25 Thickness 1.000" Venting Uni-directional (straight vane) Standard Finish Standard Optional Finish Slotted and Plated Bolt Pattern 5 x 5.5"
Important Information
Minimum wheel size: 15
Front Wheel Brake Upgrade
Part # 158-2
Product Features
Disc to disc upgrade to larger than stock single-piston cast iron calipers. Bolts to stock spindles.
Includes Turbo slotted rotors with Xtra Life plating.
Vehicle Applications
1994-1999 Dodge Ram 1500 (2WD)
Caliper Specs
Name Number of Pistons 1 Piston Size 80mm Constructed From Cast Iron Standard Finish Optional Finishes
Rotor Specs
Diameter 11.61 Thickness 1.272" Venting Uni-directional (straight vane) Standard Finish Slotted and Plated Optional Finish Drilled Bolt Pattern 5 x 5.5"
Minimum wheel size: 16
Dont Forget to Check out my other parts for sale !!
here is the Thread Links
http://www.dodgetalk.com/forums/showthread.php?t=241486
http://www.dodgetalk.com/forums/showthread.php?t=241487
Let Me Know if you are interested !!!
Product Features
Caliper Specs
Rotor Specs
Part # 158-2
Product Features
Caliper Specs
Rotor Specs
