Electrical stays on when the key is in the off position. Battery keeps draining. Could this be from a faulty ignition switch?
Discussion Starter #4
Also the key can be pulled out in all positions. It comes right out even with the engine running. We're going to change the ignition lock cylinder this weekend. Do you think that might solve the problem?
Admin - David Mack
There's a power on delay relay circuit. It keep some of system powered for a short time after you shutdown the engine. That relay maybe bad.
