21 - 40 of 83 Posts
440 WARWAGON said:
When I lowered my 75D100swb I cut one coil off the front & cut off the bump stop.On the rear I flipped the frt hanger over & cut the shackle's in half I then welded a piece of 1"x2" in the middle making them 8"long. It drives ok a little bouncy in the front dont use s6 springs with a big block or any v8 for that matter! It also wheel hops if I dont have my pinion snubber on.I will be changing it over to a spring under with cal tracs & rancho shocks.
How much did it drop the front end?
Save
440ww - how did you flip the front hangers? I just got a 80 shortbed - the guy cut the coils like you, and he torched the rear springs at the rear shackle - but it still isnt low enough (still about a 2 inch rake) so I want to drop it more, but the way he torched the springs, I will need to section the bed support rail that sits right above it.
If I reverse the front hanger like you, will that drop me anymore, or will that just realign the pinion angle a bit? I was also considering cutting the rear shackle like you suggest, or getting a set of the drop shackles (same thing) but doing that along with the torched springs has me a lil sketched.
lowering kit
We are selling a complete kit to lower the 72-93 half ton Dodge truck and Ramcharger 4" front 6" rear $819.99 + shipping add $20.00 for powder coated arms
parts are also available individually +shipping
boxed-bucket lower control arms with ball joints $545.00 add $20.00 for powder coated arms
springs (1.5 coils shorter than stock $85.00
front shocks (they will not bottom out) $22.00
rear shocks (they will not bottom out) $45.00
shock plates-mounts $50.00
spring perches (must be welded to the rear housing) $25.00
u-bolts all 4 $25.00
stock length springs also available for a 2" drop front $75.00
installation at our shop $450.00
the rear is a flip. It puts the rear on top of the leaf spring. No cutting required to the frame in the rear.
In the front we use a bucket style lower control arm and shorter springs.
The bump stops must be shortened or removed in the front which is the only cutting you need to do.
also fiberglass interior trim molded off of nos 93 plastic interior parts coming soon. put the 1993 LE interior in any 1972-1993 truck
We are located near St. Louis in Wood River IL. For installation and ordering
contact Eric at Mid America Customs 618-407-7374 or eric@midamericacustoms.com
midamericacustoms.com under construction
http://img.photobucket.com/albums/v390/jerggy13/c7374b0e.jpg
do ya think if I painted your company's logo on my truck you could give me some free arms I mean some Canadian advertising would do ya some good. LOL I wish, but those do look like damn good pieces
Save
I recieved my control arms from Eric at Mid America Customs. WOW they are awesome pieces thet look to be almost indestructable. I will post up pictures as I do the installation. :rck:
Save
hey ramble bee can u show some pics of the rear stripe you have? i thought about doing about the same thing to mine but its going to say adventurer inside of the circle. id really like to see what yours looks like to get an idea of mine thank you
21 - 40 of 83 Posts
