Hello, can any of you help guide me on some install info for the following?
Shocks: All 4 of mine are due for replacement (bouncy riding).
I thought I'd start with shock replacements (they do need replacement) before I look into added leafs or air helpers (the van is an extended/15 pass a GVR of around 5900 and rear of van gets loaded with some weight when it's used - band touring van. The rear two bench seats removedto hold gear)
I've ordered 4 KYB shocks (to replace myself - musician $ intake here and it's rough in this economy). I decided on KYB gas-a-justs after reading a bit here.
2 KYB-KG5403 fronts
2 KYB-KG5418 rears
I've done rear shocks on my 87 dodge mini ram van, and on my 85 chevy s10 4x4...but this will be my first time doing them for this 2000 dodge 3500 5.9L van.
I've got a service manual but looking for more tips on doing this job myself, what I'll need and what will help. The rear shocks should go smoothly but I'm worried about doing the fronts. Can anyone provide some advice?
What to remove, advice, etc.?
HEADLIGHT BULB REPLACEMENTS>
I also bought some new britelight wagner bulbs for my headlights as I don't like the rather dim light I have now on the roads (tougher and worse in rainy conditions).
Is this a pretty easy replacement...I can just replace the bulbs, correct?
or are there some things/tips I should know for this install?
My headlight glass could also use some clarity/polishing...it's a little bit faded.
Not sure if this is on the inside or outside of glass though. Anything I can do there?
Bought all parts for this van via rockauto (came to $190.00 total).
2 KYB-KG5403 fronts
2 KYB-KG5418 rears
