1 - 17 of 17 Posts
Undercover ninja
'Tis a super secret ricer trick: It helps the gas burn better. One combustible material + a combustible fuel = SUPERDUPER GO FAST FUEL!!!:rck:
Toothy Critters Rock!
black powder or smokeless powder?
don't know either way just curious
Pb Pes
Who did you buy your gas from? Some refineries allow for a higher sulfur content to remain in the mix after refining. Try changing brands of gasoline.
Just my .02.
To the OP, is your exhaust new? If it's new, the smell you are experiencing is a coating burning off the metal (coating is protecting the metal, and also is some residue from the manufacturing process) and will only be temporary.
If you haven't touched the exhaust it could very well be something in the fuel you're using that makes it smell that way. Have you experienced any odd fuel consumption or has your truck been acting funny while this is happening?
I RECOMMEND FUKKEN WAX
It's probably just a banana in your tail pipe.
Did you use an octane booster?
Otherwise is your truck still running the same or not as good??
We need more info .....
My exhaust smelled funny after dumping in a few gallons of 110 leaded I need to get rid of.
I assumed the it was the lead fouling the cats. That was 10kmi ago and I swear there is still a different smell, but performace wise everything is tip top.
Well if it isn't using any fluids (incl. antifreze) I wouldn't worry!
You been fueling at taco bell?
You guys make me grinn :thatfunny
1 - 17 of 17 Posts
