Bidedunit said:
Whats kdp? Im really getting frustrated with this truck but when i look @ 750$ a month for 5 yrs i quickly get unfrustrated this truck is really confusing i hauled a 28 ft sundowner loaded with 3 horses all weekend and kept my speed down below 65mph and didnt lose a drop of oil
There's an alignment dowel pin for lining up the timing gear case to the motor block.
On 12 valve motors and some 24 valve motors, the pin hole was the same diameter through the gearcase and didn't have enough interference fit so the dowel pin slowly over time vibrates out of the hole and falls into the spinning timing gears. Sometimes it gets knocked into the oilpan without hurting anything, sometimes they get in the gear mesh and really tear up things.
Which motors have them loosened is up for grabs and the rate of incidence is scarce on 24 valve motors. If I have the front of mine off for any reason, I'll pull the cover and check.
Have you looked under the motor at the aluminum gear case between the harmonic balancer and the motor block? Is there a crack or a hole wet with oil?
I've read of oil pan bolts getting loose too.
