1 - 20 of 21 Posts
Anyone know what P 0133 is ?
What is that in English?
Discussion Starter #6
OK,Thanks. Maybe someone else will read this and be able to tell me for sure.
replace the o2 sensor on the driver side top one
Hotty Toddy Gosh Almighty
Yup, bad O2 sensor. Nothing too serious, as they are a maintenance item and will eventually wear out.
Discussion Starter #9
What is the degree of difficulty to replace it on a scale of 1 to 10 with 10 being th hardest?
Not even 1. Could be a 10 if you don't have a wrench.
LMAO!!!! What about a socket no ratchet?
Thats a 9, cause you can get creative.
I can accept that! LOL Hey just a quicky what's the 1.5" Torsion Bar Crank listed in your mods?
Oh yea nice avitar!
A socket won't work because of the wires. I think it's a 7/8 open wrench that fits those. I little tip. Spray some WD40 or some other kind of "break free" lube a wait for a couple minutes. The sensor will loosen much easier that way. Good luck.
Its where you tighten the torsion bar adjusting bolts thus increasing the preload on the torsion bars which results in it lifting the front end higher.
slambony said:
Oh yea nice avitar!
Thanks, its my old girlfriend from Oklahoma. I took her out for some modeling photos one time for her birthday.
An Army of One
Those O2 sensors aren't cheap, got one when i had the exaust put on and right at $70 at Advanced, but I didn't have a chance to shop around!
Old girl friend Yea? So you just cranked it in to lift 1.5" I thought it was something eles sorry. P.S. heloace they make a socket with a slot for the wire to go thru J.M.O. :D
1 - 20 of 21 Posts
