I know the code means no cam signal at PCM,How do I fix this error and where is the camshaft position sensor located?
Neon bug bites again
The cam sensor is located on the right side of the cylinder head (if your looking at it from the front of the car). I see it happen all the time on neon's. you could say its a common problem. Befor you just go out and replace the sensor check the wiring to it from the pcm, to make sure its not a break in the wires. Other wise theirs not much else that can cause this problem besides it being completely unplugged.
Thank you for the advice but I located the cam shaft sensor and replaced it and the car started right up and it also cleared the check engine light.
Ok, good to hear ya got it fixed. If ya need anything else feel free to ask.
