I am getting this code do you have any idea how to fix it or to trouble shoot the issue?
My van runs great for a 1991 with 180k+ miles on it.
Thanks for your help in advance.
:gr_patrio
What happens if I do not fix or repair this solenoid?
The CEL stays on and you might have OD intermittently or not at all.
If landyacht318 is kicking around perhaps he might chime in on this. I think it was him that had the lockout solenoid wires chafe against his bellhousing and cause him some troubles.
When lockup is faulty, trans will likely overheat or run too hot (maybe motor too), and fuel mileage will likely drop.
...Sig says it's 3 speed, so no OD to intermittently drop out of when trans is too hot.
