Hey guys, a bit of a dilemma... I can buy a 400/727 combo for $400 and was thinking about do that but what all would be needed as far as the trans/transfer case/driveshafts go? I already have motor mounts.
The 400/727 was out of a car and my truck is an 84 w150. Would I just have to swap tail shafts to get it to bolt up to my transfer case? Or do I need a different transfer case?
Any info on a swap woud be greatly appreciated... because although my 360 runs good(minus the over heating prob I'm in the process of fixing)... I know the rear main seal is leaking, the trans is leaking(turns the snow under the truck a pretty pink color
), and possibly a few other seals.
What do you think, invest in a swap of some sort or just fix the good'ole 360?
