Engine Stall at Low RPM's
852 Views 1 Reply 2 Participants Last post by  kennethpruett
Need some help, I have a 96 3.3L. Recently at low RPM's the engine stall's. Can anyone tell me if there is a sensor I can check that controls the Gas flow?
the engine seems to run fine if gas is held down and the RPM's are kept between 2-3, but as soon as i let off the gas it stalls.
I checked for codes and nothing came up.
Any places to start looking appreciated.
1 - 2 of 2 Posts
May not be just gas flow but one place to check might be fuel filter.
Also check the engine area for hoses pulled loose. Hissing sounds is a clue that a hose might be off or have a hole in it.
Check the PVC hose as it is prone to collapsing due to the oil buildup inside it that softens it.
Another thing to check is for a clogged air filter.
Others might have more input on the gas flow and fuel rails as I have not had to troubleshoot that before.
Ken
1 - 2 of 2 Posts
