In have a 1998 ram v8 fuel injected 4X4. Here is the problem. Just noticed that when driving around 40-45 mph my engine begins to vibrate. i accelerate and the vibration stops. I feel the vibration in the front of the vehicle and a little bit into the steering column. i have had the check engine light come on and had this checked. i am told the code is that an oxygen sensor (1 of 2) is malfunctioning. At times the check enging light turns off and then will come on again weeks later. Currently, the light is on and i am now getting the engine vibration, (it is very noticable). I asked a local repair person and he said he would not be able to tell from what i told him if it was the injectors or the transmission. i have used the seafoam additive to see if this would help. No help at all. Yes, i have replace all spark plugs and distributor cap earlier this year.
any ideas out there? thanking you in advance.
