I have a 1997 Dodge Ram 1500 5.2 liter engine. Heads were replaced earlier this year due to a crack. I had some recent problems with coolant in cylinder 1 spark plug hole. I pulled the plug and coolant was dripping off of it. I waited for the plug to dry off and did cylinder leakage and compression tests and everything came back within spec. The truck ran fine for about 2 months and this past sunday I pulled in the neighborhood and the engine made a noise as if i blew a tire. It wasnt a tire it was my engine, so i hit the throttle and the whole truck started to shake violantly, and a grey smoke came out of the tail pipe. I got it home and reinspected the engine and there is coolant leaking from underneath the head, and lower down the block also, but only in the area of cyllinder one. I needed some advice of what to be looking for, and what this might possibly be.
Thanks.
Thanks.
