P000f-fuel System Over Pressure Relief Valve Activated
P0016-crankshaft/camshaft Timing Misalignment - Bank 1 Sensor 1
P0031-o2 Sensor 1/1 Heater Circuit Low
P0037-o2 Sensor 1/2 Heater Circuit Low
P003a-turbocharger Boost Control Module Position Exceede Learning Limit
P0046-turbocharger Boost Control Circuit Performance
P0049-turbocharger Turbine Overspeed
P006e-turbocharger Boost Control Module Supply Voltage Circuit Low
P006f-turbocharger Boost Control Supply Voltage Circuit High
P0071-inlet Air Temp Sensor Rationality - Ecm
P0071-ambient Air Temperature Sensor Performance (tipm)
P0072-inlet Air Temp Sensor Voltage Too Low - Ecm
P0072-ambient Air Temperature Sensor Circuit Low
P0073-inlet Air Temp Sensor Voltage Too High - Ecm
P0073-ambient Air Temperature Sensor Circuit High (tipm)
P007c-charge Air Cooler Temperature Sensor Circuit Low
P007e-charge Air Cooler Temperature Sensor Circuit High
P007e-charge Air Cooler Temperature Sensor Circuit Intermittent/erratic
P0087-fuel Rail Pressure Too Low
P0088-fuel Rail Pressure Too High
P00af-turbocharger Boost Control Module Performance
P0101-mass Air Flow Sensor "a" Circuit Performance
P0102-mass Air Flow Sensor "a" Circuit Low
P0103-mass Air Flow Sensor "a" Circuit High
P0106-manifold Absolute Pressure Sensor Performance
P0107-manifold Absolute Pressure Sensor Circuit Low
P0108-manifold Absolute Pressure Sensor Circuit High
P0111-intake Air Temperature Sensor 1 Performance
P0112-intake Air Temperature Sensor 1 Circuit Low
P0113-intake Air Temperature Sensor 1 Circuit High
P0116-engine Coolant Temperature Sensor Performance
P0117-engine Coolant Temperature Sensor Circuit Low
P0118-engine Coolant Temperature Sensor Circuit High
P0128-thermostat Rationality
P0131-o2 Sensor 1/1 Circuit Low
P0135-o2 Sensor 1/1 Heater Performance
P0137-o2 Sensor 1/2 Circuit Low
P0141-o2 Sensor 1/2 Heater Performance
P0148-fuel Delivery Error
P0169-water In Fuel Detected For Too Long
P0191-fuel Rail Pressure Sensor Circuit Performance
P0192-fuel Pressure Sensor Low
P0193-fuel Pressure Sensor High
P0201-fuel Injector 1 Circuit/open
P0202-fuel Injector 2 Circuit/open
P0203-fuel Injector 3 Circuit/open
P0204-fuel Injector 4 Circuit/open
P0205-fuel Injector 5 Circuit/open
P0206-fuel Injector 6 Circuit/open
P0217-coolant Temperature Too High
P0219-engine Overspeed
P0251-injection Pump Fuel Valve Feedback
P0300-multiple Cylinder Misfire
P0301-cylinder 1 Misfire
P0302-cylinder 2 Misfire
P0303-cylinder 3 Misfire
P0304-cylinder 4 Misfire
P0305-cylinder 5 Misfire
P0306-cylinder 6 Misfire
P0335-crankshaft Position Sensor Performance
P0336-crankshaft Position Sensor Performance
P0340-camshaft Position Sensor Circuit - Bank 1 Sensor 1
P0341-camshaft Position Sensor Performance - Bank 1 Sensor 1
P0381-wait To Start Lamp Inoperative
P0400-egr System Flow Mali Function
P0401-egr System Performance
P0402-egr Flow Excessive Detected
P0403-egr Control Circuit/open
P0404-egr Position Sensor Performance (diesel)
P0405-egr Position Sensor Circuit Low
P040b-exhaust Gas Recirculation Temperature Sensor 1 Circuit Performance
P040c-exhaust Gas Recirculation Temperature Sensor 1 Circuit Low
P040d-exhaust Gas Recirculation Temperature Sensor 1 Circuit High
P0420-catalyst Efficiency Bank 1
P0461-fuel Level Sensor 1 Performance
P0462-fuel Level Sensor 1 Circuit Low
P0463-fuel Level Sensor 1 Circuit High
P0471-exhaust Pressure Sensor 1 Performance
P0472- Exhaust Pressure Sensor 1 Low
P0473- Exhaust Pressure Sensor 1 High
P0480-cooling Fan 1 Control Circuit/open
P0483-cooling Fan Speed
P0487-egr Airflow Throttle Control Circuit A Open
P0488-egr Airflow Throttle Control Circuit Performance
P0489-egr Control Circuit Low
P0501-vehicle Speed Sensor 1 Performance
P0513-invalid Skim Key
P0514-battery Temperature Sensor Performance
P0516-battery Temperature Sensor Circuit Low
P0517-battery Temperature Sensor Circuit High
P051b-crankcase Pressure Sensor Circuit Range/performance
P051c-crankcase Pressure Sensor Circuit Low
P051d-crankcase Pressure Sensor Circuit High
P0521-engine Oil Pressure Sensor Performance
P0524-engine Oil Pressure Too Low
P0532-a/c Pressure Sensor Circuit Low
P0533-a/c Pressure Sensor Circuit High
P0541-intake Air Heater Control Circuit 1 Low
P0542-intake Air Heater Control Circuit 1 High
P0545-exhaust Gas Temperature Sensor Circuit Low - Bank 1 Sensor 1
P0546-exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 1
P0562-battery Voltage Low
P0563-battery Voltage High
P0571-brake Switch 1 Performance
P0572-brake Switch 1 Stuck On
P0573-brake Switch 1 Stuck Off
P0580-speed Control Switch 1 Circuit Low
P0581-speed Control Switch 1 Circuit High
P0585-speed Control Switch 1/2 Correlation
P0592-speed Control Switch 2 Circuit Low
P0593-speed Control Switch 2 Circuit High
P0601-internal Memory Checksum Invalid
P0604-internal Control Module Ram
P0606-internal Control Processor
P0607 Ecu Internal Performance
P061a-etc Level 2 Torque Performance
P061c-etc Level 2 Rpm Performance
P0622-generator Field Control Circuit/open
P0628-fuel Pump Control Circuit Low
P0629-fuel Pump Control Circuit High
P062c-etc Level 2 Mph Performance
P0630-vin Not Programmed In Pcm
P0633-skim Secret Key Not Stored In Pcm
P063c-generator Voltage Sense Low
P063d-generator Voltage Sense High
P0642-sensor Reference Voltage 1 Circuit Low
P0643-sensor Reference Voltage 1 Circuit High
P0646-a/c Control Circuit Low
P0647-a/c Control Circuit High
P0652-sensor Reference Voltage 2 Low
P0653-sensor Reference Voltage 2 High
P065a-generator System Performance
P0698-sensor Reference Voltage 3 Circuit Low
P0699-sensor Reference Voltage 3 Circuit High
P06a4-sensor Reference Voltage 4 Circuit Low
P06a5-sensor Reference Voltage 4 Circuit High
P0700-transmission Control System (mil Request)
P0850-park/neutral Switch Performance
P125a-power Enable Control Circuit Low
P125b-power Enable Control Circuit High
P1272-a/c Clutch Control Circuit 2 Low
P1273-a/c Clutch Control Circuit 2 High
P1274-a/c Clutch Control Circuit 2 Open
P1275-a/c Clutch Control Circuit 2 Overcurrent
P1277-starter Control Circuit 2 Low (tipm)
P1278-starter Control Circuit 2 High (tipm)
P1279-starter Control Circuit 2 Open (tipm)
P127a-starter Control Circuit 2 Overcurrent (tipm)
P127c-fuel Pump Control Circuit 2 Low (tipm)
P127d-fuel Pump Control Circuit 2 High (tipm)
P127e-fuel Pump Control Circuit 2 Open (tipm)
P0127f-fuel Pump Control Circuit 2 Overcurrent (tipm)
P141a-exhaust Gas Temperature Sensor 1 And 2 Signals Swapped
P144e-egr Cooler Bypass Status Line Circuit Low
P144f-egr Cooler Bypass Status Line Circuit High
P1451-diesel Particulate Filter System Performance
P1484-catalyst Overheat Detection
P1506-crankcase Depression Regulator Valve Performance
P1507-crankcase Filter Restriction
P1508-crankcase Filter Restriction - Replace Filter
P2000-nox Adsorber Efficiency Below Threshold - Bank 1
P2002-diesel Particulate Filter Efficiency Below Threshold
P200c-diesel Particulate Filter Over Temperature - Bank 1
P200e-catalyst System Over Temperature - Bank 1
P2032-exhaust Gas Temperature Sensor Circuit Low- Bank 1 Sensor 2
P2033-exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 2
P2080-exhaust Gas Temp Sensor Circuit Performance - Bank 1 Sensor 1
P2084-exhaust Gas Temp Sensor Circuit Performance - Bank 1 Sensor 2
P2121-accelerator Pedal Position Sensor 1 Performance
P2122-accelerator Pedal Position Sensor 1 Circuit Low
P2123-accelerator Pedal Position Sensor 1 Circuit High
P2127-accelerator Pedal Position Sensor 2 Circuit Low
P2128-accelerator Pedal Position Sensor 2 Circuit High
P2227-barometeric Pressure Sensor Rationality
P2228-barometric Pressure Circuit Low
P2229-barometric Pressure Circuit High
P2262-turbocharger Boost Pressure Not Detected - Mechanical
P2266-water In Fuel Sensor Circuit Low
P2267-water In Fuel Sensor Circuit High
P2269-water In Fuel Condition
P2299-brake Pedal Position / Accelerator Pedal Position Incompatible
P242b-exhaust Gas Temp Sensor Circuit Performance - Bank 1 Sensor 3 -diesel
P242c-exhaust Gas Temperature Sensor Circuit Low- Bank 1 Sensor 3
P242d-exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 3
P242f-diesel Particulate Filter Restriction - Ash Accumulation
P244a-diesel Particullate Filter Differential Pressure Too Low
P244d-exhaust Temperature Too High For Particulate Filter Regeneration Bank 1
P2453-diesel Particulate Filter Pressure Sensor A Circuit Performance
P2454-diesel Particulate Filter Pressure Sensor A Circuit Low
P2455-diesel Particulate Filter Pressure Sensor A Circuit High
P2457-exhaust Gas Recirculation Cooling System Performance
P245a-egr Cooler Bypass Control Circuit /open
P245c-egr Cooler Bypass Control Circuit Low
P245d-egr Cooler Bypass Control Circuit High
P2463-diesel Particulate Filter - Soot Accumulation
P2503-charging System Output Low
P2504-charging System Output High
P2509-ecm/pcm Power Input Signal Intermittent
P254c-pto Speed Selector Sensor Circuit Low
P254d-pto Speed Selector Sensor Circuit High
P2579-turbocharger Speed Sensor Circuit Performance
P2580-turbocharger Speed Sensor Circuit Low
P2609-intake Air Heater System Performance
P268c-cylinder 1 Injector Data Incompatible
P268d-cylinder 2 Injector Data Incompatible
P268e-cylinder 3 Injector Data Incompatible
P268f-cylinder 4 Injector Data Incompatible
P2690-cylinder 5 Injector Data Incompatible
P2691-cylinder 6 Injector Data Incompatible
P2a00-o2 Sensor 1/1 Circuit Performance
P2a01-o2 Sensor 1/2 Circuit Performance
U0001-can C Bus
U0101-lost Communication With Tcm
U010c-lost Communication With Turbocharger/supercharger Control Module
U0121-lost Communication With Anti-lock Brake Module
U0141-lost Communication With Fcm (tipm)
U1403-implausible Fuel Level Signal Received
U1412-implausible Vehicle Speed Signal Received
U1421-implausible Ignition Key Off Time Received
U0001-can C Bus
