1 - 2 of 2 Posts
Hey! I'm trying to help my sister out with her '01 stratus r/t. It keeps blowing the engine control fuse and won't start. It happens intermittantly and she hasn't noticed any similarities between incidents.
Just wondering if this is a common problem or if it has happened to anyone else before for I start researching. I already did a search on this forum but didn't see anything.
TIA,
groove
Scan the PCM for errors. Check all the plugs, connections, and wires underhood for wear and damage. Intermitant problems are the worst! With enough short to blow the fuse, the wire/componant causing the short should show signs stress.
Be sure all the grounds are not rusted. Poor grounds can cause many issues. With the battery out of site, many forget to check it's connections until it fails.
1 - 2 of 2 Posts
