I have an 1977 Dodge B200 318 Sportsman Van, and need diagrams for emission wiring and tubing schematics.
Ah..okay. I thought you were refering to the side marker lights mounted on the front fenders. I see you talking about the turn signals mounted in the grille.I've checked the marker blubs, they are the same blubs as the turn signal blubs, when I check if power is coming into socket from ground to power point in socket, there is power to each point. Turn signal or marker both have power to them. But when I put blub in socket only the turn signal side of the blub works, when I turn the head lights on the marker side of blub does not work but turn signal does work but also turn signal marker lights in dash come on and stay on until I turn lights off. I know I've said this before, any way it's raining here now and won't be able to check out stuff you gave me for a few days. But I'll let you know. THANK'S FOR YOUR PATIENCE.
You might want to make notes for anything you readjust, such as how far you turned a screw left or right. This way when you have to go through inspection again you can reset everything back to where it is now and pass without having to go to a shop.jblack95673 said:Hi Guys
maybe if I adjust the carb back some it will run better.
