First off, thanks for the advice before from many, sorry I can't really contribute any knowledge to the forum, this truck is really my learning to be a back yard mechanic truck. I assure you, that when I have some know how, I intend to give back
I have a 1985 d250, 318 2bbl, automatic ( hopefully that is the important stuff)
When I got it, coming off the line it would kind of surge, didn't seem to have v8 power, but I contributed that to god knows if the engine has ever been rebuilt or how many miles are on it.
When I got up to, I believe 15 to 20 mph, it would take off some and act more normal with no surging. Uphill was crappy power. It took forever to warm up, when it did, the low speed surging would die down a little.
After two weeks I noticed, that when idling, the headlights would dim a little, but a rev of the engine would bring them right back up.
Left it sitting for a few days, and went to start it, nothing, but the headlights would come on dim, I pumped the gas pedal a few times and it started groaning, then fired up.
I have changed the fuel filter, as I have no clue if and when it was done, popped the caps on the battery, it was low. Put it on a trickle charger for a while, did the same thing, nothing, then pumped the gas pedal, groaned and started. Backed it out the driveway, to move cars around. Turned it off, then went to turn the key again, fired up no issues with needing to pump the pedal. ( I should state, whoever had it before me put a lexus battery in it, so, it could have been new, used, who knows)
I was also told it had a new voltage regulator, but he was pointing at what is to me an alternator, and it looks fairly new compared to the rest of the engine. I checked all the wires on it, the two red and green in the back the connections were loose, tightened them up, I have no clue what they go to. They have like very small canisters on the bottom of them with springs (n my haynes manual is not clear on it). I also cleaned the battery terminals. I will also state, there are connections which go nowhere, even though everything seems to work.
I had a minivan where the battery went bad, and it surged similar to this truck, only much worse. I was thinking car at first for the surging, but, it seems okay, but lack luster at speed.Which is why I changed the fuel filter. I was planning on runninga few cans of sea foam through the tank.
Checked the EGR , put my fingers underneath and didnt feel the movement that the haynes manual said I should have, and it looks old, was planning on replacing the PCV as it is cheap and dont know when it was done.
But, I am thinking electrical somewhere...any ideas ?
Please keep in mind, I am a neophyte, but willing to get dirty, I have a good ohm meter, but not schooled on using it other than to check fuses. I have already ashed my knuckles on it and bled on the engine, so it officially belongs to me now
