1 - 10 of 10 Posts
I'm wondering if its possible to switch tb's. I have an 08 4.7l and don't like the electric tb. I want to put a 72mm tb that's cable driven. What do I need to make this happen. I need better throttle responce.
Discussion Starter · #2 · (Edited)
I know I can use airrams adapters, buy a tb, buy a cable, but will I need custom tuning.
More then likely ill need to cut and splice wires.
Come on, someone know anything about this.
SRTs wanna b like me
i think you would need to swap pedal assemblies and then run your own throttle cable. on the wiring side im sure it would just be a matter of splicing the new TPS into your existing harness and u should be done. but thats just going by theory
Premium Member
X2
The TB is going to be tied into everything from the temp of the engine, the ABS system, to the transmission for traction control. I’d say you’re going to need a custom tune to pull it off and even then, I believe it’s going to be a maybe of a job.
Well this suxs... I guess I'm off to plan b.
ya probly way more trouble than its worth. whats plan b? :D i always like your plans:drivingz:
Plan b is to see if Ryan can port my throttle body. I need better throttle response. I really need a tuner.
ya a ported TB would be great for ur throttle response.
how do you like the power from the '08? CAI, ported TB, exhaust and a tune should compensate and distract you from the laggy system
1 - 10 of 10 Posts
