1 - 2 of 2 Posts
I would like to install an Electric Radiator Fan, are some better than others ? I need one for maximun cooling abilities, not so much for the performance gains. What about the coolant/washer bottles, does their relocation differ with different fans? What about the controller/module, good/better/best? Are the shrouds a direct bolt in? I've read prior post on these fans but have never heard the pro's & con's on the different brands. Your opinions are appreciated. Steve
Steve, A fellow brother from my neck of the woods. I was born and raised in St Petersburg.
Some are using the Viper Fan and some are using the Mark III Fan. Im not so sure of the controller that everyone uses, but if you search for "Electric Fan" you will have HOURS of reading including several writeups on how people have wired them.
From what I have read here, Cooling is not an issue. Seems that the Viper fan with the proper controller is cooling better than the Clutch Fan without even kicking into "High Speed".
Good Luck!
1 - 2 of 2 Posts
