Well my truck popped code P0406 today. So I went by Advanced and had them look it up. Turns out to be the EGR valve is bad. I have the extended warranty. Is this covered under warranty since it is part of the emissions? Advanced told me that it is a dealer part anyway.
ok did you try resetting the PCM to see if the code will go away? i would start there, if your not wanting to hit up the dealer i saw an EGR valve on ebay this moring. ill find a link for you.
EDIT just looked on ebay its for the 06+ and it does not look like the correct one for the ram i think it might be for the cars
I just replaced the EGR valve on my 04 last week. Very easy to replace, took about 20-30 minutes and the cost from the dealer was $67. The valve requires 2 different gaskets. It comes with the larger size gasket but you need to buy the smaller one. Bee was running really crappy at about 25-39 MPH and would stall sometimes when braking to make a turn. runs like new now. :rck:
Hey guys, time has come to replace my half shafts on my 07 Ram 1500 TRX4. It’s got a 6” lift and I run 22R35s are there any brands you recommend avoiding? Any aftermarket brands highly recommended?
Thanks in advance,
Shelby
There is something wrong with my ram 1500 starter.Sometime starts and sometime nothing.
I have checked the starter solenoid ,battery as well as the cable connections,all of they are good.
I assume the problem is the starter itself,since it's has been used for about 7-8 years.
If I asked a...
So i been have a really tough time having my truck get a proper alignment and for it to drive down the road without having to shimmy the steering wheel left and right to keep it riding straight
its a 2006 dodge ram 2500 lifted 6 inches on brand new 37 toyo open county rt tires
has a synergy hd...
hello all
have a 04 2500 2wd 180,000 ml
towing a 7,000 5th wheel
5.7
nv4500
4.11
thinking about building engine
looking for thoughts on ether stroking 5.7 or doing a 6.1 swap local engine builder recommended the stoker for the torque
