1 - 14 of 14 Posts
Wired the damn thing up last night and tested it in the driveway. Everything worked. Drove to work this morning and left it closed. So now I go out to show it off to a frien and NOTHING!!!!!!! :VHOT: :VHOT:
It's raining here but you'd better believe my but will be under there today trying to get it squared away.
I RECOMMEND FUKKEN WAX
****in chuck norris
6.1 FTW
I'm having a similar problem with my new (to me) DMH e-cutout. Does yours TRY to move? Can you hear the motor trying to move when you are pressing the switch? I think I may have mine a little bit binded by the way I installed it. I can hear it trying to move but it doesn't move. Or it will move sometimes but just a little. It worked fine just sitting next to the truck not installed.
pyrokid said:
What are you wiring?? What is it wired too? What is an e-cutout???
No disrespect, but if you have to ask those questions you probably won't be able to help him.
Discussion Starter #10
Got it squared away. Checked all the damn wiring and it was solid. The cutout didn't come w/ torque specs for the bolts so I wrenched it on there pretty good w/ the crush gasket. I had the bolts too tight around the motor oin and it was not allowing it to move. While I was doing the re-wire I just cut out my cig lighter power altogether to ensure a good connection. Pics and Vid.
Switch Location:
Video:
Friend said it was bouncing debris off the ground onto him.
http://s42.photobucket.com/albums/e303/PO-POMAX2K/?action=view&current=100_1519.flv
Dodge For Life
very nice.... sounds good....
Hey man...non taken, but would it have been so much to ask as just to say exhaust cut-out? Sorry I was just trying to learn something....and never underestimate who you don't know....
sweet
6.1 FTW
Awesome dude thats what I thought your problem was. I did the same with mine. I need to losen up my bolts. I torqued those suckers on there with a fury!
1 - 14 of 14 Posts
