1 - 12 of 12 Posts
I am looking at leveling my 96 Ram by just lowering the rear end using a set of drop shackles. I do not want to lower the front if I don't have to, I am just looking for that level look. Has anybody done that? If so did it look good when you were finished?
What a ride...
I did my 98 a month or so ago. I like the way that it looks but I wil say that I was a little disappointed. I purchased 2" lowering shackles and it only dropped the truck by a little over 1". I then removed the overload spring and that gave me another 1" and did make the truck look much better.
Do you have to use hangers or will just the drop shackles pretty much bolt in place and do the trick? Like I said I am not going for a crazy drop just to level it out.
hot2k1ram
on 4x2 trucks the rear is 4 inches higher so to get a level look shackles and hangers are requires and u can keep your overlaod spring in if u want, that was the first drop i did to my truck and i was happy with it
What a ride...
hot2k1ram, what drop kit do you have on there now? I would like to get mine a little lower but not sure what to go with.
hot2k1ram
well im going to be changing it pretty soon, i went the cheap way and just got 2" coils, shackles, hangers , but im getting different coils,lower control arms so i can get the camber right, notching the frame in the rear so i can drop the truck down level with the front and belltech nitro drops shocks all around. and a hellwig sway bar for the rear are all on the way right now
belltech makes good quality stuff, u can get all the drop parts from them, DJM is good too, i would suggest changing the lower control arms (shorter) or spindles if u have an earlier model truck, dropping it with coils springs gives you a bad ride and the upper control has no upward travel, shackles and hangers are good for 4"s of drop in the rear, or a flip kit can get you 6-8"s of drop in the rear but that requires notching the frame so u can have some axle travel
anybody know where i can get lower control arms and a tranny xmember??
hot2k1ram
streetbeatcustoms.com carries the fullline of belltech lower parts
RAM MAN, it looks like a totally different truck now
Originating Member
thanks
those are older pics when I just dropped the rear with shackles only
Now I'm using the full blown drop from Bell Tech (well, its the 2/4 drop) and with that - I used dropped spindles (and new Moog ball joints) and lowered shackles and hangers
1 - 12 of 12 Posts
