Ok so i wanna go 4/6 drop i have a 2003 dodge ram single cab and im looking at the mcgaughys kits, the #94005 is for the 02-05 2wd dodge rams single cab the one i need but its $680. And then they have the #94006 is for the 02-05 quad cab dodge ram and sells for $580. My question is will the quad cab kit fit my single cab, are the spindles and coils different?
Redtruck-VA
The perfered kit is front spindles and rear flip kit. This allows you to use the stock springs and shocks in the front and maintain correct suspension geometry, the rear comes with shock extensions and the stock shocks can also be retained. Good luck.
