I may have already missed this discussion but I'm posting my problem regardless. Right now my '04 HEMI AWD has about 44k on it. Under acceleration, the drivetrain has an unmistakeable whine coming from somewhere around the transfer case and or rear end housing. As soon as I let off the pedal it nearly goes away. So, that being the case I can say that it only happens under power and not when coasting. Mainly this refers to which side of the ring-gear the pinion is in contact with (side of the teeth that is). In the old Mopars which I'm familiar with, this whining sound is common with worn-out gear sets especially with 3:55 ratio and numerically higher. Usually, they only were noisy if you were either "on-it" or "off-it", but generally not both. Has any one else experienced this condition. It seems to be getting worse, but the vehicle still runs fine. Have I missed a TSB or something? I have the 80K warranty on the drivetrain, so nows the time to get it fixed. Any thoughts? thanks all, jeremy
