Hello, Cool site..glad I found it.
I have a 98 QC 1500 4X4 8ft. bed.5.9 auto trans 3.92 open diff. I am going nukin' futs over a growl type noise and vibration that occurs only when the trans shifts to OD at approx. 45 to 55 mph.Feathering the throttle,I can keep making the problem occur. It sounds as if the ring and pinion are having a tooth to tooth brawl. however, I have completely disassembled the rear twice and see no evidence of any problems in there. Since I had it all apart, I installed all new bearings, races, axle bearings everything in a set-up kit. I have checked the carrier bearing assembly and all u-joints and nothing seems loose. I have checked the trans. mount and engine mounts and all seem good. I have put the truck in 4wd high and on a level lond dirt road, it still occurs. Has anyone expierienced or heard of any simular problem?
Thanks, DARTGT63
Thanks, DARTGT63
