1 - 2 of 2 Posts
I just had some 4.56's and an Auburn limited slip installed and everything has been going fine during my breakin period. The other day i went above 80 mph for the first time and i have a vibration that continues all the way up to 95 mph when i started shutting it down and then it goes away when i get down to 75 mph. I was told that the driveshaft may need to be balanced and i think this is a possibility, has anyone else experienced this after a 4.56 install? And this is on a 04 QC.
Just had mine installed and i am well past break in period,I have had no problems (knock on wood)...I have heard a couple of guys say that since your drive shaft is spinning faster that if is just a little bit out of whack it will rattle you like crazy...Could be a u-joint?!? But i would bet the the drive shaft might be tweaked a little.
1 - 2 of 2 Posts
