Does anyone have a pdf on taking these doors apart. I have to change one of my chrome handles ( passengerside) due to an inccident from someones door hitting mine in a parking lot. I have a 2009 Dodge 1500 Laramie. 5.7 Hemi... Also could someone tell me on these truck should the power mirror bottons and arrrows be illuminated. Just checking to see if I have a lamp issue (drivers side). Looking at removal of door skins ect...
Thanks
1. Using trim stick C-4755 or equivalent, release the door switch/bezel (1) from the door trim and disconnect the electrical connectors (2), if equipped.
2. If equipped, remove the manual window crank (1) using a window crank removal tool (2).
3. Using trim stick C-4755 or equivalent, remove the mirror flag (4).
4. Remove the screw (2) and remove the interior handle bezel (3).
5. Release the plastic push pins (1).
6. Raise the trim panel (6) upward far enough to disengage the hooks on the back of the panel from the inner door and the door lock knob from the top of the panel.
Very Nice!!!!!
This and any thread containing PDFs of our trucks should be a sticky.
Real Men Drive Mopars!
i would not say a sticky cause next thing you know there won't be no place for reg. threads but maybe moved to sep folder when their traffic stops
