Door sagging...
4 reading
1.5K views 4 replies 4 participants last post by  BigGreenV10
#1 ·
My drivers side door is sagging. I already adjusted where the lock connects to on the frame to its lowest position. I know my next move is to change the hinge pin but there is another part I noticed has gotten worn out. I want to say its a door stop. Anybody have a clue what it is so I can go ahead and replace that too when I do the hinge pin?
Sent from my electronic hunting buddy
Save
#2 ·
not a true fix but a temp. fix is to loosen the top hinge bolts and the romove the bottom hinge bolt and install a washer or 2 (might need to adjust a few times to get it right) and it will level it up nicely
Save
#4 ·
the pins arent always the problem. like n my truck the door its self is warped like somebody used it to climb in and out. .
Save
#5 ·
Why would someone do that...... oh wait nevermind.
Save
