I shorted the dome light circuit out. I check all the fuses and they all looked good I am assuming I shorted out an accessories relay. Does anyone know which relay it might be or is it a fuse that looks good that is bad?
Thanks for the help.
Dodge Tech
check your recalls i think i have seen one for dome lights in the sprinters. ill look it up in dealerconnect in a few
Dodge Tech
the recall is number g27 it involves replacing all bumbs and 2 new light assemblys
Discussion Starter #5
shillelagh said:
Did you check both fuse blocks? 1 is under the steering wheel & 1 is at the side of the drivers seat. Good luck.
Matt Murphy
Thanks Matt it was a fuse under the steering wheel.
