Official qwerty thief
I have taken apart many 1G and 2G sedans and i have never found them to have Sub inputs so i would assume that they are all the same and no, If you want to know how to get the dash apart tits diff for !g and 2G for a 1g you hve to take the dash shroud off wich is 5 screws, 4 behind the radio hvac trim peice and one in the fuse box on the left side of the dash, if oyu have a 2g then you have to just pop off the peice that goes around the radio and contains the hvac. If your looking to put subs on the stock radcio you cna go to any stereo supply store and get a little box that can do that, what you do is hook it up to either your front or rear speaker wires (i recomend rear) and then it gives you a pair of rca inputs.
Moose
no the stock radios do not you will need to use a line level converter and then you can hook p an amp. I used one for a while till I started to build my system up
