Hi all,
I really like the idea Bherder had regarding setting up the relay upgrades in a box like later model vehicles do. So, last trip to the jy I did some “research” and found a couple of good possibilities for the box. I kept my search to the Dodge family of vehicles. I have attached pics of what I picked up.
The fancy option would be the box from a 2000 ish Voyager. It is really heavy duty and has lots of spaces for relays and fuses etc. It has a pretty neat pivot arrangement to access the bottom of the box if needed. Problem is it big and has way more spaces than I think I/we would really need, its internals are inside a riveted part of the box and the factory bracket doesn’t fit well under the hood.
The one I will start my project on is from a 1995 Caravan. It is about half the size of the other, has slots for relays and fuses, the top and bottom (for internal access) both open fairly easily, but should not fall open if bouncing around off-road, the relay schematic should be easy to relabel and has a mounting bracket that should easily fit near the battery tray. The pics show the ’95 box in it’s various parts.
The items I plan on wiring into the box are; headlights, wipers, electric fan, horn (possibly), and any additional lights. I also noticed there is a relay for the starter. Would there be an advantage to wiring this into the truck’s system?
My next step is to figure out how the relay/fuse wiring modules are set up to see how I would best go about rewiring it. I also would like to figure a way to totally weather proof the box. What I would like to get my hands on is a wiring diagram of the box. I have not been able to find one online. Any suggestion or comments on this project would be appreciated before I dig into it.
L
L
