Dodge Ram Fog Light LED Bulbs! Upgrade your lights! Plug & Play Install! USA Made SLF
Diode Dynamics offers LED bulbs for replacement of your Dodge Ram's fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your Ram's fog lights a nice bright white that closely matches factory-equipped HID lighting! Just simple plug and play, replace the bulb and you are good to go!
Diode Dynamics carries the brightest, highest-quality bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed in-house by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
SLF: 850 lumens. Much brighter than factory. These are bright! USA Made!
*SLF is available in 3000K Yellow 5700K Color temperatures
Bulb Design
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Dodge Ram).
Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
1994-2001 Ram 1500
2003-2009 Ram 1500 (Non-Sport)
2010 Ram 1500
2011-2012 Ram 1500 Sport
***More Sizes Available on our site!****
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Brightness:
Bulb Design
1994-2001 Ram 1500
2010 Ram 1500
Thanks for looking!
Nick C.
