from a report in Autoweek:
Even in these times of declining sport/utility vehicle sales, the big profits are still in SUVs. The problem for Dodge was that it had only one SUV, the Durango, even though the SUV boom had long since boomed and was well into busting. Well, it turns out you can do what’s called “platform sharing,” see, where you take an existing vehicle and with a couple of adjustments here and there, you get a whole new SUV for pennies on the dollar. Who knew?
Sure, Dodge seemed a little slow to realize this, especially because its competitors have, like, six or so SUVs each, but once it figured this out, it got right on it. Dodge took a Jeep Liberty and slapped on new sheetmetal, new interior, slightly longer suspension arms and then, as the Germans say, Achtung!, you got yourself a whole new profit center.
The Dodge Nitro is built on a Liberty that has been stretched four inches, mostly in the wheelbase—the Liberty is 104.3 inches between the wheels, and the Nitro is 108.8. The Nitro tracks about an inch wider, too. While the suspension geometry is basically the same, it is just a little longer in the Nitro. Overhangs are relatively short, so it can probably crawl over a few more rocks than those minivan-based crossover SUVs in the marketplace.
Dodge didn’t want this to look like a crossover. Inspiration for the exterior came from the 2002 Detroit auto show pickup truck, the M80. While there was no business case for the M80, design elements from it are plastered all over the new Nitro: Note those pronounced wheel arches, abbreviated overhangs bordering a long wheelbase, squared-off corners and a bold, upright Dodge crosshair grille.
Mechanically, it shares a lot with the Liberty from which it came. The base engine is the Liberty’s 3.7-liter V6, basically a 5.2-liter Chrysler V8 with two of the cylinders chopped off. It feels raspy at anything over 3500 rpm but nonetheless makes 210 hp and 235 lb-ft of torque, enough to keep the nearly 4000-pound Nitro going strong. The 3.7-liter comes mated to either a six-speed manual or a four-speed automatic.
The more refined and more powerful engine is the 4.0-liter V6, a stroked descendant of the 3.5-liter used in the LH cars, Concorde and Intrepid. That engine makes only a little more power and torque—260 hp and 265 lb-ft—but does it with less thrashing and a bit more authority. It comes mated to a five-speed automatic.
All Nitros are available with your choice of two four-wheel-drive systems, both single-speed with no low range. A part-time four-wheel drive (2-High and 4-High) is available now, and a full-time all-wheel-drive system is expected in early ’07.
How does all this work? Our first drive was in a top-of-the-line R/T, which comes standard with the 20-inch wheels all the kids are crazy about, as well as a unique suspension setup to handle the stiffer tires. The result isn’t too harsh—Dodge engineers did a good job of salvaging ride while trying to make the most out of the short sidewalls they had to design around. Steering was a little numb, but this is an SUV, after all.
Ride was better in the base SXT we drove next, with 17-inch wheels but with even less precision in the steering. The SXT had the four-speed auto that has no option for third gear, only D, 2 and 1. A third-gear hold would have been nice going up and down the mountain roads we tackled that day.
Dodge is making no sales predictions for the Nitro, but anything incremental is good, right? Prices range from $19,885 to $25,900, including destination.
We can’t wait to see what else Dodge will make now that it has discovered SUV platform sharing.
