The car shakes at 55 mph, only. I have play in my oem pass. side axle with 160,000. The Good Year store manger ASE tech. said the transaxle bearing is probable bad too. I see there's a housing with 4 bolts I'm guessing the bearing is under there. That shaft was very hot to the touch after the 45 min ride to the shop the drivers side was not. Just saying. The trans fluid is at the correct level, just a side note. Should I replace the transaxle bearing too, with this mileage? Maybe pull out the bearing to see what it looks like? How do you pull it out? 05 neon 2.0 160,000. I myself just replaced all motor mounts, struts, did balls struts, and alignment. Replaced the head timing belt ect.
