1 - 20 of 25 Posts
I just installed a set of DJM lowering shackles and noticed they hit the spring mount on the inside. Has anyone else noticed this , I was told DJM has sold hundreds of these kits to dealers .
I think you have them on backwards...
Yeah as Dan said, check them out and turn them facing the other direction. Certain brands have a front/back so to speak, even though they don't mark them. Hope that solves it for ya. :tup:
KB
OK well i looked at my shackles and like i thought there are no notches. I'm thinking i can machine a notch in them like some of the other brands have.
Just because there is no notch doesn't mean they still aren't on backwards, having a notch only makes it easier to tell. Also, if your bolts are in backwards that could cause a problem as well. Not sure if they can go in backwards but if they could that would be a problem.
I believe they need to turn them around looks like the out board of the shackle is shaped different and the open end needs to face the other way.
They arnt suppose to hit, Just take 1/2 hour out of your day and turn them around and your problems will be solved.
they look the same just the angel this is a picture that slammed 1 posted
The angle they are installed isnt the conern, its the clearance on one side vs the other. It obviously isn't hitting by much so if you were to take the picture you have above, take out both bolts, and turn it 180*, keeping it at the same angle but putting that red bushing I can see on the right side of the pic on the left side instead may solve this problem. Either that or a BFH
i had the same problem with my djm drop shackles. i took mine off and turned them around......then took them off and swapped sides and still had no luck, so i ended up notching the corner where you have it circled.
A little notch solves everything. :)
too bad u just didnt buy slammed1's shackles ;P
but yeah notching will fix it all.... you should see where its been hitting just notch out the corner... just not tooo much
1 - 20 of 25 Posts
