Bubba_Hemi said:
Thats a good idea. Terminal blocks work great. They do make little metal "u-clips" to jumper the post together instead of using wire.
Bubba_Hemi said:Did this during the week... was finishing the install on my backup cam and had to run a long wire from the rear to the front for a switched +12V. While under the dash... I found one I could use. However I'd already tapped into it once (for my gauges). Thought about that and everything else that I've done or plan on that use either a switched or constant +12V source and decided to put in a distribution block.
Went to AutoZone and found something that would work just right... and it does. It fits nicely where I put it.
A little hard to see in the pic... but the far left post is for the switched +12V and the other 3 are for the constant +12V. I just ran the actual power to the far right and jumpered from there to the one next to it and then next to it. I also put an inline fuse for the constant +12V line... that way I can just pull it and work on it without the fear of melting my screwdriver to anything.![]()
Bubba_Hemi said:Well, I had wire laying around... although I did have to buy the ends I used.
I hope the "metal 'u-clips'" are insulated except for the ends...
