1 - 12 of 12 Posts
Ok truck is a 06 w/hemi 59k miles coolant level in the overflow drops about 2inches every few days can't find a leak anywhere can't smell antifreeze truck runs great idles great no smoke and the oil looks good replaced the rad cap last week no change any ideas are greatly appreciated thanks in advance
I've got an 04, just turned over 100k. Had the same issue. Turned out to be a leak at the thermostat gasket. Replaced that and been fine since. Hard to spot without a mirror or some contorsion. Not sure if it's a similar problem, that sounds like a significant leak.
Biggin
rent a pressure tester and pump the system up and just watch it over.
Discussion Starter #4
that makes it even more confusing did a pressure test it held 17 for 20mins never went down:confused:
Biggin
wtf really??? Dip test the coolant for combustion gasses.
Im wired!!!
X2
I'm having a similar problem.... I have an '04 and when it sits for more than a day I get a little puddle under the center of the engine bay a little forward of the oil pan. So I'm thinking thermostat seal. Don't want to hijack this but what does everyone think?
Discussion Starter #9
update been driving the truck for 2 days with uv dye to find leaks just got back from my buddys shop no leaks found did a co2 test for bad head gasket came back neg so where can it be going no leak and no bad head gasket:ugh
Discussion Starter #10
i would think if you have a puddle you can climb under your truck and see where it is leaking from in the front of the oil pan it could be thermostat water pump or rad hose
Biggin
sure it's not the weep hole for the water pump itself?
Same problem on my 04'
1 - 12 of 12 Posts
