MA Audio HK2000D
HK2000D Digital Class X Competition Mono Block Amplifier
Features
* RMS Power at 14.4V: 750W at 4 Ohm, 1000W at 2 Ohm, 1500W at 1 Ohm
* RMS Power at 17.0V: 1000W at 4 Ohm, 1500W at 2 Ohm, 1800W at 1 Ohm
* Fuse Rating: 40A x 4
* Dimensions (W x H x D) 12.4" x 2.71" x 14.29"
* Temperature, Voltage & Output Level LCD Display
* Thermal, Short & Overload Protection Circuitry
* Platinum Plated Screw Type RCA Jacks
* Double Sided Black Epoxy PCB Board
* Platinum Plated Block Terminals
* Fully Unregulated Power Supply
* Stainless Steel Finish Heat sink
* Quiet Fan Cooling System
* Remote Gain Control
* Full Mosfet Circuitry
* Frequency Response: 10Hz - 350Hz
* 24dB Low Pass Filter: 50Hz - 350Hz
* 24dB Subsonic Filter: 15Hz - 50Hz
* Variable 0 - 18dB Bass Boost Control at 45Hz
* RCA Input Sensitivity: 0.2 - 8V
* Low level Input Impedance: 22K Ohms
* Damping Factor: 200 at 4 Ohm
* 1 Ohm Mono Stable
Specifications
RMS Power Range 750-1800 Watts
Number Of Channels 1
Maximum Power 1800 Watts
Low Frequency response 10 Hz
High Frequency Response 350 Hz
Built In Crossovers Yes
Channel Separation Yes High
I have it wired for 1 ohm operation, the alternator is 165 amps and all the wiring is new 4 gauge pos/neg. The capacitor has a digital readout, which fluctuates with the bass. I was thinking of buying the accuvolt or maybe a bigger capacitor.
