21 - 37 of 37 Posts
Discussion Starter #21
Please Read the warning posted on their site for reference :teacher:
Thanks for the screenshots but I believe that warning is regarding the potential for hydro lock if you pour too much in too fast.
I see no warning ANYWHERE that this chemical is corrosive to rubber parts.
In fact Jim at Sea Foam told me just the opposite, "Sea Foam is petroleum based and will not affect rubber components and even through you used the other port all Sea Foam got sucked into the motor."
So why do I now have a hole in the booster diaphram?
MAYBE it's a total coincidence - but still very suspect.
Discussion Starter #22
Sorry to bring the bad news. I looked it up on rockauto.com and a new brake booster (A-1 Cardone brand) is $100.89 plus a $40 core charge for a 2004 hemi anyway. That's not horribly bad. I sort of expected $250-300. You might find one at a pick and pull for cheaper. I wouldn't expect many people go to the junkyard for brake boosters.
I already looked it up too!
No, it's not horrible but if it was "self induced" damaged then I am really pissed. That's what I get for trying to maintain my truck in good shape.
NEVER DOUBT THE DEMON
people stall their truck out by putting the hose in the container and sucking as much as the motor can take in this process, hydrolock is not their concern, Petroleum is gas, gas will eat rubber that is not designed to be used in gas situations, which is why we have fuel hose and rubber hose, your brake booster does not have rubber in it designed to have gas on it for extended length of time...
it all boils down to this is a self caused problem, not a problem with the product used, your brake system says only use brake fluid for a reason
'11 5.7L R/T Classic
I looked at the "info" on the brake booster on rockauto and there are several failure scenarios laid out by the manufacturer. The primary one seems to be running rich, which to me says that even petroleum based products can kill the gasket.
Discussion Starter #25
Yep, I read that too.
And I also agree with Demon Hemi - the brake booster is intended to handle AIR only. Any fluid of any kind can eventually damage it.
I've learned an expensive lesson here. New brake booster on order.:ugh
So your 1 local guy is better than my 1 forum guy? :)
I agree, a consensus is a good thing. When no one spoke up I ASSUMED it was good advice.
my local 1 guy did it daily at a local oil change place ;)
thats the only reason i trusted him :cool:
i do TONS of research before i do anything to my motor, or anthing that can cause a problem on my truck, just like when i do a custom light idea, i buy a spare set of lights to try on first, gotta cover your grounds, now i know most wont buy another car to try on but like i said i do weeks to months of research first and YOUTUBE is your friend trust me lol
I did mine through the right hose and still had the same problem as Jebb. I have lived and learned.
I am not trying to be a jerk but there is no way in hades, if you do the treatment properly, that the SF enters your BB. It is just not possible for the liquid to magically travel through the air and enter the BB through the exposed nipple nor is it possible when the line is hooked back up to travel against the engine vacumm suction and enter your BB. Your SF treatment just happend to coincide with a failed BB "if" you truly did do the treatment procedure properly.
I seriously mean no offense but it is just not possible for the SF to enter your BB and cause the failure if you use the main line to do the treatment.
Discussion Starter #32
Just curious, but what is the typical life of a brake booster?
I live in Los Angeles and use the brakes A LOT however I called my local Dodge dealer and he found none in stock in the entire area - nearest source Arizona.
So, it seems, failure is rare.
Got 2 Hemis
Used correctly and by the instructions (combined with a touch of common sense), the Sea Foam is being pulled AWAY from the booster. Even when the hose is reconnected, it's still pulling away from the booster. Misuse of the product is not Sea Foam's responsibility. Sorry to rain on your parade.
I used to work auto parts. Did it for quite a few years actually. Both dealer( Ford )and aftermarket( local state parts chain and a Napa ). A failed BB while not something super common is also not rare. I sold quite a few BB's in my day. I can't speak to how common it is on the 3rd Gen Dodges as I was out of that line of work by the time they came out. BB's failing though, in general, is not uncommon nor rare. Keep in mind ALL parts fail.
However, just as a note. Don't take the fact that there are none locally as a sign of the part being rare. Parts are hard to come by these days for all auto mfg's. You could call around and look for the most common part you could think of and find them on infinite back order. I have been waiting for a month for a valve stem/tpms for my 2008. Still back ordered. Had 2 go bad and they were only able to get one.
The parts mfg's took a big hit when the economy tanked and the auto mfg's had financial issues. Getting parts can be a real nightmare now. The BB not being available locally to you is not a sure sign or how common it is for it to fail.
Besides, you performed the procedure improperly by your own admission. So if the failure truly was due to SF entering your BB because you used the secondary nipple on the BB then it is on you and again not an indication of the problem being common or rare. You broke the BB it didn't mechanically fail on its own if the SF caused the problem.
i have to agree on it not being common just because its not around locally, i waited 3 months for a air bag off switch for my 05 because dodge had em on national backorder
21 - 37 of 37 Posts
