1 - 12 of 12 Posts
Well the key trick does not work on my 04 HEMI RAM QC. I followed the instructions of the video... got the Chime. A/C stops working & doorlocks/windows as well... but after a few minutes everything works again... I try to go past 105... but no cigar...
I guess I have to spend the $300 for a stupid chip...
5 Years... 6 Dodges
Is that the one where you turn it back or turn it forward? I know I've read where both work so you might try the other way.
I only found the one that you turn back one click & wait for the chime... that's the one I tried.
I'll search for the other... thanks...
5 Years... 6 Dodges
Yea, I'm pretty sure there were some that got it to work by turning the key forward. Apparantly with the truck in gear if you do that, it doesn't engage the starter and allows it to work.
Vertically-Challenged
Turning the key forward you hear the chime then things turn off for a second then they turn back on. Then you can go balls to the walls!
Is this the key trick that gets rid of the speed limiter?
Discussion Starter · #8 ·
Truck must be in gear to turn the key forward? I have not had any luck finding the key forward trick doing a search... only the one click back video...
How about a chip? I tried doing a search to see what people were using... only found that the Jet chip was not a good choice... any other options?
Dodge User
superchips mircotuner
5 Years... 6 Dodges
Superchips isn't out for the 04s as far as what I've heard...
And yes, the truck should be in gear for the key forward trick. Otherwise it'll jsut engage the starter again.
SuperChips needs to hurry their asses up!!
I sent them an email about 2 weeks ago requesting info on the '04 tuner.
Their answer was vague . . .
ITS SO SLOW !
the trick will work in park the new dodges have a no double start feature meaning it will no try to restart it will give you the chimes and you are good to go
1 - 12 of 12 Posts
