Nodo you have MDS disabled?
I can do that tonight I'm currently at work. Should I go ahead and return the truck to stock until you can look over the tune or will that mess up the data you need?Are you running the 9r02 revision?
If you are can you e-mail me your last tune written?
You will have a slight surge due to torque management reduction when mds kicks in and out.
Ok, up to you, i have not really heard of any issues with 08's but that would be your call.I can do that tonight I'm currently at work. Should I go ahead and return the truck to stock until you can look over the tune or will that mess up the data you need?
Also I noticed with or without he tuner the RPM's seem to be higher when the truck is in 4cyl mode on the highway, which seems odd to me since the higher RPM uses more gas. Anybody else notice this?
Yes the latestOk, up to you, i have not really heard of any issues with 08's but that would be your call.
You are running the latest rev 9r02 right?
When you turned off MDS did you lose the little bit of gas mileage you were getting?yes, when MDS was not disabled i did notice it ran at slightly higher RPM's and had the surge you are describing. now its smooth as can be
no, i actually gained about .5...not much but even if i would have lost 1-2 i would be ok because the sound and surge were enough to make me punch a baby
Well the mds uses a torque management spark table to dampen the "kick" , we alter that table and unfortunately the "kick" is a side effect of altering that since it will not use as much spark reduction to dampen it.
