-Force Design Concepts is more than just Camaros. We've done extensive work on both classic and modern Mustangs, Chevelles and other popular muscle cars...we're even in the process of building up a 1966 Thunderbird. Jason Huber, G-Force Design Concepts' owner and manager, came across a cherry early 70's Sublime Dodge Demon at, of all places, a Mustang shop. He found that the car was for sale and shortly afterwards it was his personal project. With the straight body and decent paint he would be starting with a car that was a bit easier on the pocketbook.
Jason got the Demon back to the G-Force shop and put together a plan to deliver maximum performance for a less-than-6-figure budget. The first order of business was to mini-tub the Demon to accomodate the 18x12 rear wheels wrapped in 335 rubber. Next would be a 4-bar rear setup to eliminate the factory leaf springs.
Bill Reilly at RMS in Pennsylvania provided the "Alterkation" front k-member. RMS specializes in modern suspension systems for Chrysler muscle cars. This system elimates the old torsion bars and uses a Mustang-base spindle, heavy-duty sway bar, and rack and pinion steering. With the use of Mustang II spindles the brake options opened up considerably. We worked closely with the GP Superstore to pick up 14" front 6-caliper piston Wilwood brakes and 14" 4-piston rear brakes with an internal parking brake.
With the major suspension design tackled we decided to use a system from Air Ride Technologies. This uses shockwaves on the front and rear with ride height sensors. The 4100I system had everything we needed to for a clean and reliable air suspension.
