I was driving a noticed about 4 weeks ago that the engine was nearing the 1/2 way on the temp meter. I took off the radiator cap and added around 1/2 gallon and refilled the resevoir. Didn't think much of it, just watched it allittle closer for the forseeable future. :huh:
2 weeks later I noticed the same thing. I took off the cap and agin filled with about 1/2 gallon. 1 week after that I noticed it again. I then proceeded to try and fing the problem. It only leaked when running, idling showed no apparent leaks. I then noticed when looking up from the ground under the passanger front wheel anti-freeze drops from 2 tubes that enter and leave the bottom of a canister toward the back lower passanger side of the engine. I felt up along what seemed to be a cove in the engine block. I thought it was a seam where a gasket may be leaking. I then had my father rev up the engine to 1600 rpm to simulate the running and leaking affect.
To my surprise, there was anti-freeze bleeding out of what was around 1/2" under the cove area until it accumulated into drops. There is no gasket, seam, or anything in this area, so I have what appears to be a crack in the block at that location.
:VHOT:
Needless to say I'm disappointed as I only have towed my 6000lb RV 8 times since I bought it, and go to work in an office daily. It is 8 years old with 91k miles, a supposed "baby" in diesel terms. The local Dodge dealer said any warranty is over, and things don't look good for the crack. It is now about 6" long and appears to be growing and losing more anti-freeze along the way. :VHOT:
Any suggestions, anybody else have this happen?? :help: :help: :help:
Thanks Z
Thanks Z
