1 - 19 of 19 Posts
Where did you guys get yours and how much were they? im not worried about them having a drain or temp fitting although it'd be nice, but i can weld them in if i have to.
Transmission Man!
muddynoll
I got my B&M Pan at Summit. I think it was around $160.
Woodstock
Woodstock- Thanks for the info and web site. Sounds like a pretty good deal for that price. Looks like I'll be purchasing one from them.
Transmission Man!
Now I would think that pan would not fit on a 46RE due to VB interference (I don't always trust what they say as far as fit applications) but if you say that it fit your 46RE fine then that is good to know! :D
Woodstock
The pan fit great. Plenty of clearance. The pan is huge compared to the stock one and has cooling tubes running through the bottom of it. The drain plug is magnetic, but I still installed the factory magnet from the old pan.
I have to thank tactransman for hooking me up with transmissionpartsusa.com or I would never have found it.
Transmission Man!
Here is another pic of it from a different angle
Transmission Man!
That one is no deeper than stock.
New Pan 46RE
Just got this pan and a Fastman valvebody. Will install tomorrow.
Transmission Man!
That is probably the best pan made! Very nice drain plug :D Very good quality.
Discussion Starter #14
where is the best spot to put the temp sensor.. im thinking on the back passengers side, close to the indent for taking out the screw? looks like it *should* clear everything in there..
Transmission Man!
I like 'em in the pan. It tells you the temp of the fluid that the trans is getting ready to use.
Mmmmmmmmm, beer.
Yes, but temps in the pan are always cooler then what the trans actually is. If your trying to avoid overheating, this is not the reading you want. If you have a larger then stock capacity pan escpecially, that fluid temps can actually stay cool down near the bottom of the pan where air flow over the pan is cooling the lower portion of fluid. This also happens to be where your sending unit usually is too. So your getting the coolest reading possible with this setup. The trans can be getting very hot, but you won't know it because you're reading cool temps in the bottom of the pan. I have seen this with my own trans since I take trans temp readings from 2 spots (the pan being one of them). Usually the pan will reach a certain temp, and then temp increases slow down, even as the trans continues to heat up at a more steady pace at the other sensor location. I once was running over 240 on my trans temp reading, but only 195 in the pan. I could have easily overheated in this condition if I relyed on the pan reading only.
Transmission Man!
I still like the pan. :D
Discussion Starter #19
oh man now im confused. i have the stock pan, and i planned on putting the sensor on the back side of the pan kinda up high. autometer recommends this i believe.
1 - 19 of 19 Posts
