Is it possible to replace the dash lights in the temp. , fan and selector controls ? Currently only the hot section of temp. works after knocking it with your knuckles ...............
yes, not easy..
Ya Its Got A Hemi
Unless your good at soldering, it would probably be best to by a new control. All of my bulbs burnt out and I pulled the fan/heat/cool controller out and found that the bulbs get to hot and blow up and yo have to replace the bulb and base which is soldered to the circuit board. . . . .very poor design IMO!
^GM Goodwrench Certified^
As far as Chrysler is concerned, they are not servicable and you need to replace the entire HVAC control head, they run about 125 bucks from your local dealer. You can crack them open and solder new bulbs in, but it is for the skilled.
