1 - 7 of 7 Posts
for all who have a dakota rt. if you have a cam what all did you have to change or did youll just slap the cam in? did you need computer modifications? what cams did youll use? i want to do a cam but i just added it up as to what mopar performance told me they said cam, rocker arms, and computer flash well over $1100. i am a mechanic so i am mechanically inclined and i dont think the rocker arms are needed, the flash i can understand.
it is a 1.7 they want me to get.
when i did my cam swap i went with Crower 1:7 adj rockers(sold the HS 1:6`s), Crower rev kit, new push rods and had to have the heads machined for new springs. so all together it was ~$1100 all together. cam is a custom Crower regrind and i dont have my cam card handy so i dont remember the specs.
all my stuff was purchased thru socaldakota.com
your ECM will need a reflash and fuel sync will need tweaking. also you will need to degree the cam.
thanks for the inout guys. i will get cracking on it because the problem i have is no higher end power after about 50. did youll notice big improvements at higher speeds?
sounds like ya got the socalled *Death Flash* was a stealership bandaid to stop ping. this was/is mostly from the belly pan gasket on the intake. once ya swap the M-1 in ya wont have that worry anymore.
this is the cam i got from socaldakota.com
206/208 .515/.515 111 lsa 107 centerline Crower
works great with stock or mild port heads and most bolt on mods.
1 - 7 of 7 Posts
